Woops, I broke it!
jvrotter
yucca valley, ca
Well, when I got my M1009, it had no tailgate glass, so while waiting to get some I was clearing up all the broken pebbles of glass, etc. I was checking the operation of the hand crank and somehow broke this piece. Looks like a bar lock to prevent the tailgate from opening until the window is completely down. Checked both LMC and another source and can't find any referance to it. Anybody know where I could order this part? Its a plastic tube that contols the metal rod. It bolts to the inside frame of the tailgate.
ranchhopper
139
south elgin illinois
Its a spring there is one on each side to assist lowering and raising the gate. They run along the bottom of the gate they twist and build tension as you lower the gate.
OL AG '89
9
Kingwood, Texas
check LMC or classic truck..... they have the parts if I remember correctly.
Also looks like the spring isn't broken just the mounts/clamps????
or do the junk yard thing
Mikey90744
ca
as long as they take standard K5 parts nothing special for the military, LMC has almost everything needed like that
OL AG '89
9
Kingwood, Texas
there is nothing "special" on the 09, that can't be procured from either GM dealer or aftermarket suppliers.
It's painted camo, but it just a civvy K5 painted camo.
jvrotter
yucca valley, ca
Yes, its just the plastic mount that broke. Maybe I'm blind but I checked the tailgate section of LMC and don't see that particular part. If someone can find it please give me the part number.
badassissimo
Iowa, la
Been hunting myself for an electric setup. I found electric rollers for the doors but haven't found one for the back glass. I'm curious if I need to get the whole tailgate because it dam near takes two hands to crank it up and down. Not sure if I can just grease it...
Blood_of_Tyrants
11
Lebanon, TN
Sounds like it needs lubrication. My back window rolled up and down easily after I greased everything inside the tailgate.
joediveguy
Front Royal, Northern VA
Toss it in the trash and forget about it. The only purpose it serves it to keep a private, or housewife, from dropping the tailgate with the window open. As long as you remember to roll the window all the way down before opening the tailgate you will be good. Save your money!
Anubis8472
Redford, Michigan
Sure most of it is the same, but you still need to check because there are differences. Springs/sending units/CDR's/seats etc.
Whether you consider them 'special' or not, there are parts not found on civvy k-5's.
In any event I don't think being 'painted camo' has anything to do with the part in question. It looks to be a difficult part to get a hold of for any 25 year old vehicle.
Is your disgust for '09's in general?
Or that the OP had the nerve to ask about this in a MV forum?
Here on the east coast Ive seen both the electric and man. in two yards the past few days, but did see more electric. glass is rare because without the batterys in truck people just smash the window to get at the motors!
ryan77
56
Cary IL
You dont need that part anyway!!! If your to stupid to roll the window down all the way before opening tailgate you shouldn't have a blazer!! Im in the process of doing a electric tailgate on mine, Bring a dewalt battery to junk yard cut the harness out of tailgate and jump it with the batt to roll the window down!!!
