Working on a "Major" Brake Adjustment
Austringer
33
Atlanta, Ga
Have a bit too much petal play (more than I like) and a little soft so I bled the line from the master cylinder to the power assist and had one or two large air bubble comes out. Now it seems to be much better, still a little more travel than I like. Since I don't know the exact history of the brakes except the wheel cylinders are new, I jacked it up, put in a jack stand and then removed the wheel. OMFG again OMFG the tires are ****ING heavy! Anyway, as I thought, the brakes did need the major adjustment (per the manual). I adjusted per the manual (through the inspection hole) and the bottoms were tight and the tops were open. Adjust both to .010 and then came the super hard part. Getting the **** tire back on. All this took a good 1 hour, not including going to get larger wrenches (1 -1/16")... Only 3 more to go.
I do have a question, how do you tighten the bottom adjusting lock nuts as I can't get two wrenches in the space at the same time due to the shield. I was able to get it fairly tight but not to the 120 ft-lbs the manual calls for. The rears will be easy.
1,172
I would use a crows foot on the center, and a wrench on the nut.
B3.3T
88
SW Ohio
We created a dedicated wrench by grinding a shallow (narrow) box end wrench. Works great.
M813rc
2,883
Near Austin, Texas
If your brakes continue to be soft after all the adjustments and bleeding, check your booster. That was an ongoing problem with mine, even though it was new when first installed (they apparently don't like sitting around in the V for three and a half years while you finish the other stuff). Napa has replacements.
Cheers
jimk
45
Syracuse, New York
FYI The stock brake linings are semi-metallic. The might have choosen them because they work better when wet, like after swimming. The manual shows the rear brake cyl is 1-3/8" while the fronts are 1-1/2". I might be wrong but I thought the deuce used 1-1/2" frt and rear.
