- 412
- 35
- 28
- Atlanta, Ga
Have a bit too much petal play (more than I like) and a little soft so I bled the line from the master cylinder to the power assist and had one or two large air bubble comes out. Now it seems to be much better, still a little more travel than I like. Since I don't know the exact history of the brakes except the wheel cylinders are new, I jacked it up, put in a jack stand and then removed the wheel. OMFG again OMFG the tires are ****ING heavy! Anyway, as I thought, the brakes did need the major adjustment (per the manual). I adjusted per the manual (through the inspection hole) and the bottoms were tight and the tops were open. Adjust both to .010 and then came the super hard part. Getting the **** tire back on. All this took a good 1 hour, not including going to get larger wrenches (1 -1/16")... Only 3 more to go.
I do have a question, how do you tighten the bottom adjusting lock nuts as I can't get two wrenches in the space at the same time due to the shield. I was able to get it fairly tight but not to the 120 ft-lbs the manual calls for. The rears will be easy.
