Working On The M561 Gama Goat
mkcoen
382
Spring Branch, TX
Got #2 tire on this morning. The fronts were the best tires I had to start and 1 wouldn't hold air and this one had serious side wall cracks. The others are 10x worse. Of course I put the best new tires on the front but even the others are worlds better than whats on it now.
Another Ahab
4,944
Alexandria, VA
I'm guessing it's the UV damage that beats up the rubber, because those 30-year old tires (likely in covered storage all that time), look brand spanking new compared to the existing tires. You know anything about rubber, mkcoen; is that it?
mkcoen
382
Spring Branch, TX
I'm guessing it's the UV damage that beats up the rubber, because those 30-year old tires (likely in covered storage all that time), look brand spanking new compared to the existing tires. You know anything about rubber, mckoen; is that it?
There's a lot of factors but UV damage is definately one of them. The problem with the tires that came on the Goat is that they were flat for a long time so sitting with a lot of weight on the side walls. The new tires were probably from a more active agency that kept them aired up.
mkcoen
382
Spring Branch, TX
Those tires do look good!
Turns out the 1st wheel I painted and put on has a different tread pattern on the tire. I guess I'll pull that one and keep it as a spare so I have the same tread on all the shoes. Still there's 90%+ on all 6 it's just the oddball one still had the center mold ridge so it was basically brand new. Hopefully it'll stay that way as I really don't want to have to break out a spare.
The tread on the full set comes half way down the side wall where as the oldball ends at the edge of the side wall.
combat32
107
Booneville AR.
You must be living right, from what I understand those are hard to come by. Is that oddball tire a good year? Got the rings today thanks,
Another Ahab
4,944
Alexandria, VA
I'm not a machinist, but I'm thinking any good metal shop could fabricate that in about 15 minutes.
Don't get me wrong; I mean it's a WHOLE lot less trouble agreed when you can just click "purchase" on the lapto; and I love that, but you know what I mean.
Where did you find the mount mkcoen?
mkcoen
382
Spring Branch, TX
The problem is, without an example you'd never fab one correctly. There is a slight angle to the pipe that doesn't show up in the photo or in the TMs. Yes I could fake it but I prefer things original if possible.
See post #386 for the story of how I got it.
TexAndy
Bee County, Texas
I can get some drops from the machinist here in town and you can give them to kieth. He can make reproductions using your mount as a model.
mkcoen
382
Spring Branch, TX
Left side tires now changed out. I also got the missing lift rings and rear tow shackles installed. Two more tires and the M60 mount and I might take a day or two off.
m38inmaine
102
Maine USA
Mark that looks much better. I too have a tire dilemma, I have like new tread but a lot of sidewall rot, not quite as bad as the one pictured. Most of them are recap tires. I did have all the lifting rings, rear shackles in the mail. I have two styles of those tailgate bumpers as well, one carrier has dual bumpers on each side and one has singles.
