- 5,637
- 382
- 83
- Spring Branch, TX
Yes it is 24v. It is designed to run in conjunction with a slave port connector on the deuce in a field environment. The slave connects to the battery pack to charge and then the MBUs run off the battery pack. Where there is "shore power" available the MBUs run through a 115/24v convertor. I doubt it could be used to jump a deuce as the power is one direction and there is no connectors to run back to the deuce batteries. Also I doubt the amperage would be sufficient. I've added a couple of additional photos of the unit so you can get a better idea of the setup.OK, so theres the batt pack I was just writing about in another thread. Is it 24vdc? Will it slave jump a deuce?
The layout is fairly simple. On the right side of the trailer (front to rear) there is a small cabinet with a cutting board top and storage under the board. This is where I keep the cooking utensils. Next is the griddle that sits on 2 MBUv3 burner units and then there are 2 "stoves" which are simply MBUs with a grate on top for sitting pots/pans. This is where I'm adding my new griddle (now I'll have 2) since I can heat a pan of water on the griddle or in the ovens any way and will now have more room to cook burgers or scrambled eggs. On the left side (frt-rr) there is a long work table with cabinet storage underneath and then 2 individual ovens, again sitting on top of MBUs. They generally came with 1 additional moveable cabinet that could be set on the folddown deck for more prep area and storage and also a large ice chest.MKCoen, I wish you had more pics of the kitchen so we could all see the components up close and how they work. I have read this thread with much interest. It is nice to get excited along with you on your project. Thanks for the writeups.
These are great trailers for taking to events and shows but if I was looking for backyard cooking I'd stick to a decent BBQ.
More on the battery pack. It looks to be a never used item with just some shelf wear. Anyone know the group size of the batteries?
