spicergear
- 28
- 0
- Millerstown, PA
Today I spent two hours laying under the truck trying to figure out how or what to do to the driver's side exhaust pipe on the CAT that originally come straight down from the manifold flange about 12-14", then a mandrel bend 90*, then straight back until it clears the back of the spring hanger, then another mandrel 90* aiming the fumes out under the frame where they go to a flex pipe then to the added stack. The first drop from the manifold could not have been any more centered in the way of the winch drive if I'd have designed it. ...oh wait, poop...I did. And, the PTO was in the way also so the pipe needed to be dealt with back there too. Anyway I either needed to bend the driveshaft around the pipe with a pillow block on a hanger somewhere...just a mess I wasn't looking forward to. I don't have anymore of the exhaust pipe I had originally used, (3.5"x .100"wall SS) so I had to make every move count. This is what I came up with. Each pic is from below or slightly beside the winch drive. WHEW!!! Oh, I've got 1/2" clearance from pipe to pan...might heat wrap...maybe. The driveshaft I'm using is going to be the driveshaft and slip yoke originally on a M715 modified a little bit. I'VE GOT A PLAN IN ACTION!!!
