Would dual snorkles on the truck increase hp?
muthkw25
739
Canton, PA
Just a question, but if you put two snorkles on a deuce and had a y at the turbo, would the truck pull in twice is much air or would it split it 50-50 for each one? I wondered if it would force more air into the engine and create more power when the fuel is turned up.
Maybe the truck would have less air restriction and cause it to work less. IDK, any help would be appreciated.
Heath_h49008
103
Kalamazoo/Mich
Is there any restriction with one? (no)
So, no.
But it would weigh something... plus cause more wind resistance... so you could think of it as a slight upgrade to the braking system.
doghead
4 Star General /Moderator
1,191
NY
If you add dual snorkels, you'll also need to add dual exhaust stacks...
m-35tom
226
eldersburg maryland
NO. and by the way, a snorkle is not to increase air in the first place, it is to get up above the dirty air near the road.
muthkw25
739
Canton, PA
I know it has a mushroom, I was just thinking of two snorkles. Thanks for the clarity.
