- 350
- 317
- 63
- Woodside CA
Allison can change the programing. I'm about to have some programing done to the TCM in my A1R. Happy to provide contact info for the Allison distributor/service center I'm dealing with. I'm in Norcal too and the Allison distributor I'm dealing with is in Hayward, so depending on where you are, you could pay them a visit. If you can clearly define what you want done over the phone, you can ship them your TCM, but it kinda sounds like your request my require some test drives to dial it in. Some programing literally needs to be done by Allison corporate. The tech I talked to said that may be the case for me, as I want the downshift target gear that is prompted when the exhaust brake engages changed from 3rd to 4th. Tech said it usually only takes a day or two for Allison to return the new profile.Yeah, a couple of times. Didn't really change anything. The system also does it automatically over time, but I spent 5 days offroad and it sure didn't autotuneThe gear ratio between 2nd and 3rd is just too wide and there is no fixing that, but if I could get it to go into 3rd at a lower rpm, that sure would be helpful. If Alison could change the programming on my wtecIII, that would be awesome.
