Welder Sam
- 6
- 0
- Glendale, Arizona
Thats the way i took it too Ron
Like it but one long box will be needed down the sides,think dropside bed, for the long pieces, and if you put a set of chains or stops on the fold down door you will have small catwalk to help with access to the gondola and I am thinking use full height even under the gondola the inside of the box would have to by shorter but the outside is ok because of cutout on bottom side of gondolaHow's this for ideas Jeff...
That is why they are SECRET, if they were ment to be seen then they would not be a SECRET COMPARTMENTI would also like to know where secret compartments 5 & 7 are they are points 8 & 13 on the drawing :screwy:
hey thats plausible.Just a thought, the m62 has 4 below deck compartments, just maybe when the 543 layout was written out, NO ONE thought to LOOK at a 543, they just assumed that there was 4 compartments like the m62.
This is no different then the 936 rear winch derating because everybody ASSUMED that everybody else was dealing with the correct pump/motor drive specs.
