Wrecker: Cupola Spreader Poles
zebedee
conceptualizer at large
815
Central NY
Just got a set of 3 spreader bars #5 for the cupola soft top hoops (#6).
These things are not shown in the Operators TM's and are relatively rare. Getting lost with the soft tops I guess.
Pretty simple in construction, a turned plug welded into tube.
I know JT (Jatonka) is getting soft tops reproduced, but I was thinking about making a batch of the plugs needed to go in the ends of tubing. An interferance fit (hammer in) could be done if welding is not available. These plugs would only require simple hardware store tube to be used to make the complete spreader bars.
If any one is interested - please let me know. A set of 6 would ship in a small padded envelope!
zebedee
815
Central NY
I should have said - not mentioned in the operators/maintenance TM's that I have read on this forum or have in hard cover.... Not telling you what I "think" I should have said!!!!
But thanks...
