Wrecker light bar- odd connections?
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Well, I got my NOS wrecker light cable in the other day, and it is beautiful!
So tonight, I pulled out my wrecker light bar and tried to hook it up.
Hmmm, seems I have a problem. Not only are the pins not lined up the same, the connection on the bar has 3 round tabs to catch, while the cable has a threaded connection.
Guess I'm going to have to find another cable, or find another light bar/light bar wiring harness with the right plug. I didn't realize there were two types or I would have checked prior to purchasing the cable.
tcody
Illinois
If you can't return it replace the plug. The correct one is a LADD HD56-18-8 I think they will loan/rent the crimping tool to you. Good luck.
tcody
Illinois
Did a little more digging on your cable. I believe it is NSN 6150-01-210-3671, which is listed as a subcomponent of the Howitzer. So I think that is the light cable for towing a howitzer, which would explain the difference in pins on the one end. Hope that clears things up a bit.
tcody
