jeep thing
- 0
- 6
- swedesboro,NJ
truck used to start with few seconds of cranking the motor, and run strong and never stall, then it changed, the truck would start as always very quickly run for a few seconds and stall,at this point the truck would take minutes of cranking to restart unless i use starter fluid,after truck would start and run for few minutes i could turn truck off then restart with no issues for up to 3 to 8 hours,after that it would be hard to start again,now the truck wont start unless i use starter fluid and even if i run it for hours as soon as i shut her down it will only restart with starter fluid,also the throttle response is like a turle compared to the way it used to be,my question is does the wrecker use a fuel pump, or does the motor vacume pull deisel from tank,will the truck run without fuel pump if it has one,buddy of mine says he has multi fuel deuce and his truck ran when the fuel pump **** the bed,ran like **** but it ran,could my problem be a fuel pump![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
