srodocker
- 70
- 48
- Lacey, Washington
Maybe put some 1600s to try and level out the trailer?
The picture is somewhat deceiving. The truck is on an incline with the rear wheels in a small depression. It actually rides fairly level when it's on level ground. You can't put larger tires on the trailer due to clearance issues.Maybe put some 1600s to try and level out the trailer?
I was going to suggest using a double oscillating fifth wheel off a 931 or 933 but I suspected some terrain deception.
I measured the outside to outside distance on the front spring hanger today and there is sufficient room to mount an axle back there.Need to move the tandems back where they should be, similar to how a M819 is set up. I would use that as a guide to set your wheelbase... if you go forward with this project.
I would imagine the only option would be hydraulic steering. Either by separate controls or an orbital valve running off of you front steering. I'm no expert, just my $.02Here's a technical question for those fabrication gurus. What would be involved in making the rear axle steer. The donor truck still has all of the steering gear so when I pull the axle out I could probably get almost everything I need to do the installation.
Because (whinny little beotch voice) I want something different.why not just move the tandems back ?
One thought would be to put slightly smaller tires on the axle and it would only contact the road if there was a heavy load on it. I've seen straight log trucks do this.a steering tag axle mounted behind the tandems would be pretty trick - especially if it could be raised and lowered as required like a m920
Edit: And on a side note, I love watching somebody try something different.
I noticed the steering cylinder sits above the frame so it would interfere with a bed unless I raise the height of the bed (thus raising the center of gravity of an already tall truck).Mount the steer axle on the rear with the steering cylinder on the passenger side. Power the axle, plumb the cylinder to counter steer the front axle, and it'll look just like a HET...
I also thought free-steering front axle would turn as needed to follow the truck in turns, the same as the front axle on a truck that was being flat-towed. You might want the ability to lock the axle straight or lift the axle so it wont go catawampus when backing. Having said that, one problem I see with a free-steering axle is that it may accentuate the push-steering action of the trailer on the truck during turns or evasive maneuvers when a Prius cuts you off....I suspect if you mounted the new rear steering axle and set the caster angle somewhere around the same as the front steering axle and put a decent size hydraulic damper on the tie rod - the new axle would just follow the truck....without scrubbing the tires and stressing the frame....
