prodro1
- 5
- 18
- Keithville, LA.
Looks great. Good Idea on the "slobber bottle"!
Do the same for the air box drain.After cleaning out the engine bay of oil, pine needles, and grime, I was convinced quickly that all that air box drainage needs to go somewhere other than the engine bay. I looked around the garage and found two brass fittings and a metal container that onced had denatured alcohol in it. I just repurposed the container to catch all the oily 353 drippings. It fits perfectly between the bulkhead and steering shaft tunnel.
Good advice but most of Mike's vehicle (other than the fuel tank and tailgate) is aluminum so the magnets don't work so goodThe cereal boxes last for awhile and to avoid any high spots or to contour better, use small magnets to help hold the stencil tight to the work, plus push it firm and use painters tape to help hold it down, before you mask around so you don't get overspray. I can put up to four lines on one piece with the 1/2 and 3 lines with the 1".
That is a killer resource you have there.I have a 3 ring binder from a retired motor pool mechanic who was a big fan of the Goat. It contains every PS magazine article ever published on the goat, also every known article published in the various military vehicle magazines. My plan is to publish a goat book with them. Must be 200+ tips on Goat repairs, would be lost without it, it's the definitive guide to what's right. I did not have the book when Mark had his project underway, got it shortly after I started mine. This is how I found the information on the correct location to mount the bridge plate. Notice that PS magazine also shows a yellow plate on a MERDC painted goat.
