fastsailor
- 0
- 0
- Chapel Hill, NC
i am still dealing with transmission errors and after some research it looks like they used a Controler out of a m1088 in my m1078 so i need to reprogram it.
do any of you have the CIN# of your wtec II controller its a programming # normally on the side next to the part #
the problem is the m1088 has compression brake and a different temp sensor as long as i get a program code from a m1078 or m1079 it should work
