Autonomy_Lost
- 1,485
- 93
- Pennsylvania
Just wanted to post some pics of a set of x doors I recently restored. I don't know what I'm doing and there was a ton of trial and error, but in the end I think it turned out pretty good.
I got some really beat up X doors for cheap on ebay. The two rear doors were pretty good except for some holes that needed to be filled. The fronts were REALLY beat up. Missing rivets, huge chunks of paint missing, no window frames, missing parts, etc.
The biggest issue was chunks of paint missing. The paint was so thick it was impossible to sand it smooth, I needed to fill the voids with something. My first attempt was using a two part epoxy. This worked okay, but it was tough to sand smoth. The epoxy didnt like making a feathered edge, when it got really thin it would just start peeling up. Then I tried fiberglass resin. This was a total disaster. It didnt bond well (probably just a poor prep job on my part) and ended up coming off in sheets.
Finally I came to the proper solution which in hindsight should have been obvious. Bondo! It goes on smooth and is easy to sand in 15 minutes. I used the reinforced bondo which seems extremely strong. If I could go back in time, I would have just used this from the beginning.
As for paint, its Behr premium which I rolled on. I plan to airbrush on the camo pattern in spring when it warms up.
Anyway the pics may now show up in the proper order, but you get the idea.
