msgjd
- 4,134
- 113
- upstate ny
1: Yeah, those black marks are telling the world your sprag isn't shifting between fwd and reverse position as it
should and the transfer case is getting bound up
2: Another situation is this: Did the truck get rolled forward while in reverse, or likewise got rolled backwards
while in neutral or a forward gear? Either of these scenarios will bind it up , even if it's just 10 feet
2: There's nothing that physically keeps you from putting the transmission/transfer in gear when self-recovering
with the front winch , but it's clearly not a good idea.. The winch doesn't spool at the same rate as truck
travel, thus it's possible to bind up the transmission/transfer if the tires grab some traction
