Xm971 adventure camper
ROCKWELL-C60
192
franksville wi
20161221_194020.jpg20161221_194106.jpg I got the upper cabinets mounted. As for the lowers I will paint to match the uppers and I'm also using some of the ceiling duck aluminum to trim everything out. I'm going to use butcher block for the bench surface.
ROCKWELL-C60
192
franksville wi
20161227_191941.jpg I paneled bedroom up front and will paint it seafoam green. I'm trying to maintain a military theme thru out.20161227_192011.jpg also hung a few panel's in the bathroom. All corners will be trimmed out in 1x1x1/16 aluminum angle.
155mm
Chief and Indian
1,246
506
Guymon, OK
What was under the plywood flooring under the tile? Is that what the 4x4 beams on 12" centers and spray foam is?
ROCKWELL-C60
192
franksville wi
So u worked on getting the cabinets in the kitchen done. I used butcher block for the countertops, the side against the wall lifts up to gain access to the plumbing, storage and trash can. 20170205_181348.jpg20170205_181410.jpg20170205_181456.jpg
155mm
Chief and Indian
1,246
506
Guymon, OK
I know it works very well on an 70" Petercar standup sleeper, but you quadruple the space and it might not do so good, but I dont know. But I do know that it worked well on a big sleeper.
quickfarms
25
Orange Junction, CA
Has anyone tried and apu (heater,ac,generator) from a semi to power a camper. There diesel powered and give roughly 12000 btu heat ac and 3000 watts 110AC and 50amps DC.
They are quite expensive.
The btu's required to heat or cool a space is dependent on many factors.
A lot of factory truck sleepers are poorly insulated and the cab windows are large and I insulated.
If you can find one that is not to costly I would try it
Sent from my iPhone using Tapatalk Pro
ROCKWELL-C60
192
franksville wi
Well there are pricey but getting a generator,heater,ac and battery charger in one seems like a good deal. The one thing I don't like is putting all my eggs in one basket.
ROCKWELL-C60
192
franksville wi
Sorry 4 delayed response, am using these cool 110 led lights from home depo. 20170928_085213.jpg20170928_085300.jpg. I'll mount them on the walls and add some brighter led ceiling lights in the back.
