Yanmar oil drain adapter
coyotegray
10
Oklahoma City
I have a couple of 3kw generators with the Yanmar conversion. They run great but I would like to make changing the oil easier.
It looks like the drain plug is metric, m16X1.5. I'm trying to find an adapter to go to 3/8 mpt or fpt so I can install a valve and drain hose...
Any ideas.
As a last resort I found the correct size bolt at ACE hardware that I can bore out to make an adapter...
Isaac-1
50
SW, Louisiana
The little Yanmar L40 powered fresh water pump I bought from GL a couple of weeks ago has such a setup with a hose that connects to the engine then a remote drain plug on the outside of the ASK housing. It is NSN 4320-01-338-8010 and there is a parts TM online for it, but I don't have it handy.
Ike
here is is
www.liberatedmanuals.com/TM-10-4320-316-24P.pdf
parts 23-36 on Figure 1 Page 3 of 4
coyotegray
10
Oklahoma City
Ike
here is is
Thanks!!
By looking at this manual I found the part TM for a larger pump unit and it took me to quickvalve.com and I was able to search for a smaller version... Perfect!!
http://www.qwikvalve.com/fumoto-f108n-valve.html
Not cheap, but better than cobbling it together unnecessarily..
ETA - Free USPS shipping from Quickvalve too!!
