Yermo, pickup non running HMMWV
Superhondaz50
66
Fort Mohave, AZ
Hi all, bought another HMMWV, it's a non running bucket. Was planning on doing a U-Haul trailer for pickup, my question is, do you know if the yard guys bring out the non running trucks with the big fork loader? If so has anyone had them use it to drop a HMMWV right onto the trailer? Trying to have all my ducks in a row for picking this up once the euc clears. Thanks
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
They will fork it and carry it out and put it where you want if it's a runner or non runner
simp5782
9,509
Mason, TN
Does anyone know the pickup timeframe? I can't seem to find an available U-Haul truck and trailer anytime soon in my area.
7am to 2pm. They are sometimes there till 4 but don't count on it.
You have 30 days from the date the item release was issued.
Superhondaz50
66
Fort Mohave, AZ
Great, appreciate it. I was able to get a U-Haul trailer rental and my sister in law is letting me use her Ram 2500. Having them fork it on the trailer will be easy, I'm gonna try to use a snatch strap to pull it off when I get it home. Should work, hopefully.
KN6KXR
647
Felton, CA
I was there about a month ago. Observed other folks getting stuff. Some notes:
-They will put air in the tires so it rolls (if they will hold air)
-If the machine moves under it's own power they WILL NOT place it on your trailer
-If the machine will not move under it's own power they will put it on your trailer BUT if you're an asshole they probably won't
-Nice bunch of guys
Superhondaz50
66
Fort Mohave, AZ
-Nice bunch of guys
Cool deal, def not an a-hole. Tires are junk for sure, the rears have fist size holes in them, engine is missing most everything so it's def no gonna start. Have had good interactions before with them, but have only bought running stuff, and one car that wasn't running that they couldn't get on a tow dolly due to the low height.
Here's a pic of the truck. Mostly bought it for the body.
Superhondaz50
66
Fort Mohave, AZ
Recovered. The forklift guy at Yermo was a pro, couldn't have gotten it on the trailer any more perfect. Was fun getting it off, didn't realize there were no tie rods, ended up using a tie down the keep the wheels sort of straight, took about an hour with a snatch strap to get it off. On another note the floor boards on this one are all shot up, looks like some soldiers had a fun day with a few M4's.
spankybear
981
WA
How did the u-haul handle the HMMWV? Do you have any idea the weight? I am working on getting the ECU thing now and have a truck in Barstow.
Superhondaz50
66
Fort Mohave, AZ
It was totally fine. I think it's rated for 7500lbs and the HMMWV is well below that at 5200ish-lbs. I rented it for a "Suburban" which is 5700lbs. U-Haul doesn't have an issue with the weight, it's the width. I used 6, 2" straps from Home Depot. 2 of them to extend the U-Haul tire loops then 2 front and 2 back crossed and hooked under. Was a fairly easy move with the exception my truck was a dead pile of crap and hard to get off the trailer.
spankybear
981
WA
Thanks! I was thinking they were around 5000 poundish... No batteries will take 200 pound off :) I am thinking my 1/2 ton Chevy will pull this combo as long as I take it easy. Can't wait!
Superhondaz50
66
Fort Mohave, AZ
Ya, a half ton shouldn't have an issue, it'll be close though. That U-Haul trailer is heavy. Prob be around 8k total if I had to guess.
