Yet another MEP003a Issue!
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
Maybe its just my headache or the fact the 002/003 market is drying up in the south so I havent touched one in a few months, but does the solenoid not retract/stay retracted while in the run position for a few seconds if the switches are good? If you have good oil pressure and its not overheating, mine have all stayed retracted for a moment until the oil pressure sensor opens at its preset.
The solenoid will retract and stay retracted for as long as the master switch is held in the "start" position. It will also stay retracted in either of the "Prime & run" positions only as long as you have oil pressure and are not overheating. The instant you turn the master switch to "off", the solenoid is supposed to drop out because you have cut the power to it, then it doesn't care what the safety switches do. It has no power so even if you still have oil pressure for a few seconds, the solenoid will drop out.
Munchies
Keesler Air force base/ MS
Ah , glad I am not crazy. Thank you for confirming my thoughts.
Yes so if the switches are operating correctly, for a brief moment after holding in start and then letting go , the master switch will fall into prime/run. Your solenoid should stay retracted until the oil pressure drops down again. This test wont work good in very cold conditions.
dependable
188
Tisbury, Massachusetts
Back to the service interval, fuel filter/oil level,...clogged fuel fitler, low oil... If you run this as much as you say, if you service oil & filters as to spec,( I know you downloaded users TM) unit will serve you. Otherwise....on an old diesel like this, would check oil level each time you fuel.
rustystud
3,392
Woodinville, Washington
I'm in total agreement ! I lived off grid for 5 years (not by choice) and the only power was the generator. You must service these units religiously ! Oil does get burned, and leaked.
