JDToumanian
- 14
- 38
- Phelan, CA
Hi Group,
My Studebaker V-18A/MTQ Earth Borer - Pole Setter has a Zenith Mechanovac Auxiliary Governor on it. This is a constant speed governor (to keep the engine RPM constant while operating the pole-setting mechanism or rear winch) that is totally separate from the governor that is integral with the Holley 885-FFG carburetor / governor (which only controls max. RPM).... It's a "sandwich style" governor with it's own throttle body stacked between the heat riser and the carburetor.
It is in need of overhaul. Both sections, the centrifugal speed sensing unit as well as the diaphragm and throttle control unit. Searches here and on Google have turned up nothing useful.
I have TM 9-8647 (Carburetors and Governors - Holley) and TM 9-1826C (Carburetors and Governors - Zenith) and NEITHER of them cover this auxiliary governor! None of the manuals specific to the V-18A/MTQ (that I own, anyway) cover this auxiliary governor. In fact, the only mention of it at all is removal / installation / adjustment instructions in TM 9-8022.
I am looking for an overhaul manual - even knowing the TM number would be helpful - and I need overhaul kits for both sections of the unit.... The diaphragm is cracked and the gaskets are all crumbly. See pics.....
Regards,
Jon
Regards,
Jon
