Zero rate
blzrgb
mississippi
I'm looking to put a set of zero rate add a leaf's to the front of my 1008 in order to move the axle a little to the front. Has anyone used a set of these? I also wondered if there would be any problem's with the adjusment sleeve on the drag link's? Seems like you'd need to trim off some of the two tie rods in order to let the axle move forward and still be able to adjust the steering.
1,172
to answer your first question, search "zero rate"! plenty has been said about them.
blzrgb
mississippi
Well thanks Einstein. Try that search yourself and see that nothing comes up. Maybe a little conversation is needed here, hopefully someone with actual experiance with this particular product will chime in. :-D
Marlboro
Mullica Hill/NJ
i used them on my 87 k-30 and like them, as for your steering i did crossover so a few turns of the drag link recentered my steering wheel. I see your concern, off road design will be able to answer your question, always been helpful with me.
1,172
OK, http://www.steelsoldiers.com/search.php?searchid=602591 or Steel Soldiers::Military Vehicles Supersite - Search Results
Everything I do know about zero rates, I learned here on SS.
btw, My first post(and every time I suggest a search), I do it to he helpful. :roll:
mtjbrown
Cohutta, GA
blzrgb, it seems to help if you do an advanced search and click the cucv forum. I did this and pulled up a couple of pages worth of threads.
HTH,
Mark
1,172
Thats odd, they did when I posted them! (I checked).
Oh well, what do I know anyways....:wink:
btw, I did an advanced search for, "zero and rate" and "zero rate" in the cucv forums.
