Dump bed mod
Therapydoc
9
Missouri
Hey guys I’m really considering making my m923a2 into a dump bed. Mostly need it to haul gravel and things like that. I’d like to be able to haul about 10 ton.
im trying to get a list of things I’ll need and get a realistic cost to transition
24v hydraulic pump and tank ( what size tank do you think ? And I assume it has to be 24v and not 12v ).
been looking for a scissor hoist on marketplace but have only seen 7 ton ones so far. I assume it has to be scissor, has anyone ever done otherwise ?
I have a buddy that can do all my welding and pivot points on the rear and tailgate modifications. How do most people do the end gate closing/lock?
wasn’t there a guy at some point in st Louis that did the modifications at a cost at his shop ? Thought I saw a post about him but couldn’t find it again
Jbulach
2,110
Sunman Indiana
Tank size depends on the hoist.
24 volt would be ideal.
Scissor is most practical (can be found well over 10ton if you dig deep enough and have the $) for low volume electric pumps.
C&C Equipment in Indiana could probably build you out for $$$.
Link to my build for ideas.
DeMilitarized
920
Gainesville, GA
Grab you a ph616-6 hoist kit and these hinges because IMO they are better quality and higher strength. That is what I am running on my m931a2 with a lmtv bed on it. I am running a pto and winch kit instead of the hydraulic pump but the electric pump should do fine. https://bushtec.com/products/dump-hinge-welded
Therapydoc
9
Missouri
fantastic. Lots of good reading in there. I appreciate it
Therapydoc
9
Missouri
any issues with hoist fitment ? See Midwest military said there’s a little more to do with the 11 ton versus the 8 ton
DeMilitarized
920
Gainesville, GA
the ph616-6 is the same size generally as the smaller units. I have a tractor and had to move the air dryer and notch the center frame support just a hair but other than that it is the largest hoist you can reasonably fit
