Anyone have picture of properly mounted air brake load sensor valve on an m1088?
Reworked LMTV
1,158
TN
I need to re-attach the load sensor air brake valve on my M1088. Anyone have a picture of this mounted that I can use as a reference? Thank you in advance!
Reworked LMTV
1,158
TN
Just need a quick picture of how this brake load sensor is mounted. I took the 5th wheel off and am trying to recall where it was mounted. Thank you in advance!
Reworked LMTV
1,158
TN
Still need a picture of this item mounted, if you can spare the time : )
Godspeed131
916
Knoxville, TN
@Reworked LMTV , here’s the pictures. The first three are from the back facing forward and the last is from the front looking back.
coachgeo
3,379
North of Cincy OH
did a search for 1088 images etc. came across this video at 1:39 there in the rectangle spot that is sunlit, between the chassis rails, right side, you see what I think is the cable going up. Hope this helps.
