Finally Joined The MEP Family
CT-Mike
CT
So it turns out that there is enough room in the sub-panel to install these directly and don't need a separate enclosure. I will post some photo's once I get them installed.
m-35tom
221
eldersburg maryland
Based on Triple Jim's suggestion above, I bought 2 of these to monitor power output from the generator:
http://www.amazon.com/gp/product/B00YY1KOHA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
i just need to find an enclosure of some sort to house them.
so this looks useful, but these units only monitor one phase (or leg if you prefer) so you need 2 and then you must add the results. seems there would be a similar unit that looks at both legs and in the process also at the sum of those legs for the total of those loads as well?
CT-Mike
CT
I do have two, one for each leg. Mostly I want these to ensure that the legs are equally loaded. I have already powered everything from the generator that I want to power and it come out to about 75%, so I am not too worried about calculating total load.
