Little rubber insert on throttle/ip cable end
FMJ
37
Las Cruces, NM
Does anyone have a source for the rubber/steel piece that goes in the throttle linkage that connects to the IP?
Crash_AF
Colorado Springs, CO
I'd be interested in a source (besides generous other members) as well. I have two throttle cables that the grommet is dead in, and the one on my 1031 looks like it's about ready to fall apart.
Joe
Sharecropper
952
Paris KY
The grommets are available from McMaster Carr, item #9600K31 "Push-in Grommet, 5/16" ID, 5/8" OD, 1/16" Thickness for 1/2" Diameter Panel Hole, packs of 100". $6.89 for 100.
Probably have to salvage the little steel piece from a parts truck.
Hope this helps.
FMJ
37
Las Cruces, NM
Hope this helps.
Thanks!
85CUCVtom
25
Lakewood, Ohio
I found the grommets at Sears hardware. They were in the hardware isle in the plastic bin. I bought a few just to have them. If you can't find one PM me and ilk see if I can send you one.
