- 7,400
- 19,124
- 113
- Charlotte NC
This thread covers the M39 family of Trucks.
TRUCK, 5-TON, 6X6,
M39, M40, M41, M51, M52, M54, M55, M61, M62, M63, M139, M246, M291, M328, M543 and M748 SERIES TRUCKS (Multifuel)
The Following Steel Soldiers Members contributed to this thread.
@sigo, Unnamed Administrator, @Guyfang, @simp5782, @WillWagner , @fuzzytoaster, @msgjd
The following Technical Manuals, are for Maintenance Instructions, Organizational Maintenance, Direct Support, Depot Parts and Accessories, for the M39 model Trucks. These TM’s pertain to all models. This list is for reference only. Check the NSN on your truck, and compare it to the NSN on the TM cover, to make sure it applies to your truck. Some of these TM’s may not be here because the distribution code is other then “A". Others, simply because we have not been able to locate them yet. If you see a mistake, please P.M. me and let me know. If you have a copy of a missing, or outdated TM, please P.M. me so we can try and post it here. @Guyfang
LO 9-2320-211-12: LUBRICATION ORDER FOR TRUCK, 5-TON, 6X6, M39 SERIES TRUCKS
MWO 9-2320-200-35-1: (Restricted)
TB 9-352: LOAD TESTING CRANES FOR VEHICLES M62, M246 and M543
TB 43-2320-426-20: HYDRAULIC AND AIR/HYDRAULIC BRAKES PREVENTIVE MAINTENANCE
TB 43-0142: SAFETY INSPECTION & TESTING OF LIFTING DEVICES
TB 43-0002-87: BRAKE FLUID, SILICONE (BFS) CONVERSION PROCEDURES FOR TANK & AUTOMOTIVE EQUIPMENT
TM 9-2320-211-10-HR: HAND RECEIPT
TM 9-2320-211-10: OPERATOR'S MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES TRUCKS
TM 9-2320-211-10-1: OPERATOR’S MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES TRUCKS
TM 9-2320-211-10-2: OPERATOR’S MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES TRUCKS
TM 9-2320-211-10-3: OPERATOR’S MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES TRUCKS
TM 9-2320-211-10-4: OPERATOR’S MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES Trucks
TM 9-2320-211-20: ORGANIZATIONAL MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M39 SERIES Trucks
TM 9-2320-211-20-1: ORGANIZATIONAL SCHEDULED MAINTENANCE
TM 9-2320-211-20-2-1: ORGANIZATIONAL TROUBLESHOOTING
TM 9-2320-211-20-2-2: ORGANIZATIONAL TROUBLESHOOTING
TM 9-2320-211-20-3-1: ORGANIZATIONAL MAINTENANCE
TM 9-2320-211-20-3-2: ORGANIZATIONAL MAINTENANCE
TM 9-2320-211-20P: ORGANIZATIONAL MAINTENANCE REPAIR PARTS
TM 9-2320-211-34-1: DIRECT SUPPORT & GENERAL SUPPORT TROUBLESHOOTING
TM 9-2320-211-34-2-1: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE
TM 9-2320-211-34-2-2: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE
TM 9-2320-211-34-2-3: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE
TM 9-2320-211-34-2-4: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE
TM 9-2320-211-34P: DIRECT SUPPORT & GENERAL SUPPORT REPAIR PARTS
TM 9-2320-211-35: DIRECT SUPPORT, GENERAL SUPPORT MAINTENANCE & DEPOT
MAINTENANCE
TM 9-2815-207-35: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE,
MACK ENDT-673 ENGINE (Missing)
TM 9-2815-210-34-1: DIRECT SUPPORT & GENERAL SUPPORT TROUBLESHOOTING, ENGINE ASSEMBLY, DIESEL, (MULTIFUEL) LD-465-1, LD-465-1C, DT-465-C, LDS-465-1A & LDS-465-2 & CLUTCHES
TM 9-2815-210-34-2-1: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE, ENGINE ASSEMBLY, DIESEL, (MULTIFUEL) LD-465-1, LD-465-1C, LDT-465-C,
TM 9-2815-210-34-2-2: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE, ENGINE ASSEMBLY, DIESEL, (MULTIFUEL) LD-465-1, LD-465-1C, LDT-465-C,
TM 9-2815-210-34P: DIRECT SUPPORT & GENERAL SUPPORT MAINTENANCE, ENGINE ASSEMBLY, DIESEL, (MULTIFUEL) LD-465-1, LD-465-1C, LDT-465-C,
TM 9-2910-226-34: PUMP, FUEL METERING & DISTRIBUTION, NSN’s 2910-116-8241, 2910-178-1185, 2910-759-5410, 2910-908-6320, 2910-968-6317
TM 9-2920-214-35: GENERATOR ASSEMBLY, ENGINE, DELCO-REMY, MODEL 1117495, 2920-735-5736
TM 9-2920-225 34: GENERATOR ASSEMBLY, ENGINE, LEECE-NEVILLE
TM 9-2920-225 34P: GENERATOR ASSEMBLY, ENGINE, LEECE-NEVILLE
TM 9-2920-242-35: STARTER ASSEMBLY, ENGINE, DELCO-REMY, MODELS 1113943, 1113904, 1113944, NSN’s 2920-00-226-6545, 2920-00-911-5637, 2920-00-912-9510
TM 9-2920-243-34: STARTER ASSEMBLY, ENGINE, LEECE-NEVILLE MODEL M0017072MB
2920-00-267-9987
TM 9-2920-247-34: GENERATOR ASSEMBLY, ENGINE, PRESTOLITE, MODE GHA4804JUT, 2920-903-9534
TM 9-2920-247-34, Change #1: GENERATOR ASSEMBLY, ENGINE, PRESTOLITE, MODE GHA4804JUT, 2920-903-9534
TM 9-2020-248-35: GENERATOR ASSEMBLY, ENGINE, PRESTOLITE MODEL MFY6101AUT
2920-00-999-6216
TM 9-2990-201-45: TURBOCHARGER, ENGINE ASSEMBLY, SCHWITZER, MODEL 4D-554, 2990-974-7583
TM 55-2320-211-15-1: TRANSPORTABILITY GUIDE FOR 5 TON, M39. (Missing)
TACOM DMWR: 9-3830-501: DEPOT MAINTENANCE WORK REQUIREMENT FOR FRONT AND REAR WINCHES.
TROUBLESHOOTING MANUAL FOR THE LDS-465-1 ENGINE.
INSTRUCTIONS FOR THE INSTALLATION OF THE CAB REINFORCEMENT KIT.
TRUCK, 5-TON, 6X6,
MAINTENANCE
2920-00-267-9987
2920-00-999-6216
