cmroles
- 0
- 0
- Phoenix, AZ
Has anyone modified the "T" block for the Oil Sampling Valve to mount an oil pressure sender?
What I'm thinking about is scrapping the whole pipe and sampling valve and having the square "T" block (the part that's actually mounted in the oil cooler line) drilled and tapped to accept the sender. I'm just curious if somebody has already done this and how it worked out. Is there any reason why this wouldn't be a good location for an accurate reading?
