Shankem-Deep
- 17
- 18
- Ada, Oklahoma
So I got around to building a steering box brace this weekend for my M1028. I noticed the steering getting sloppy awhile back and it turned out to be the bolts holding the steering box to the frame coming loose. I tightened them, but they kept working loose after only a short time. I had read that it is possible for the frame to crack at the steering box. ORD offers a really nice looking brace but i didn't want to shell out for it right here at Christmas.
Here's what i did:
Here's what i did:
- First i made the mounting spacers. I had some 3/4 round stock that I cut into 3 2" lengths and drilled a 29/64 hole through for the 3" long 7/16-14 bolts.
- I had a 1/4 x 2" strap that i used for the main body of the brace. I cut a 3" piece and a 16" piece. I used the 3" piece to go between two of the spacers that bolt to the steering box. You will need to notch it to clear a couple hard lines.
- I bolted the steering box on using 2 of the spacers and the new 3" grade 8 7/16-14 bolts. Then I put the 3" piece of strap between the spacers and spot welded it to the spacers.
- Next I drilled out the hole in the front cross member using a 1/2" drill bit.
- Then I took the 16" piece of strap and roughly laid it against the front side of the piece I just spot welded and got an idea of how i was going to have to twist it and bend it to line up with the hole in the cross member
- So after a few trips to the vise bending and twisting, i drilled a 1/2 hole through the end that would bolt to the cross brace. Then I welded the other 2" spacer over that hole.
- I then bolted it to the cross member and tack welded the other end to the front side of the 3" piece.
- I then took everything off, added a couple of braces, finished welding it and painted it.
- I used blue locktite on the bolts when i installed it
