Welder Sam
- 6
- 0
- Glendale, Arizona
thats my kind of instructions right ther!
![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
hey gimp.... MOOBS are no laughing matter!
and use the rear throttel control to raise the rpm to at least 1400rpmNot sure about the 816s, but in mine, you push in the clutch, put the trans in 5th, put the transfer in neutral, and pull the lever behind the door latch forward to engage the pto. Then you go lift stuff!
I didn't see the possom??Wow! That must have been the first video Wreckerman ever starred in.![]()
Couldn't be it has sound!!!!!!!!!!Wow! That must have been the first video Wreckerman ever starred in.![]()
Yea hand throttel in cab will not work and the rear throttel is a Govener control.my rear throttle is frozen. hand throttle in cab makes it run up to 2k in the third notch. first 2 notches make no difference. will, have to chase it down. sure makes mounting 395's on recentered hemmts alot easier than by hand!!
thanks! im figuring it out slowly! its a whole nuther creature than what im used to but it seems like a great truckLooks great, glad you are using it
