59 gas Deuce air cleaner
Redpawn
St.Cloud FL
I just picked up a pair of deuces over the weekend and one of them has a gas motor. To my supprise I got it running very easy but the air boot to the air cleaner was missing and some critters made a nest at the top half of the air cleaner. Is there any way to disassemble the air cleaner so I can get all the trash out of it? I took the bottom off the can and the last element out but the rest don't seem to come out. Heres the two trucks on the tailers.
hndrsonj
Senior Chief/Moderator
361
Cheyenne, WY
Both Memphis equip and Antelope Valley truck parts have the complete gasser assemblies relatively cheap.
xm708
vermont
nice load
I have to ask what do you have that combo registered for weight wise ? Between the truck trailer and load you must have been over 30,000 ?
ed
Redpawn
St.Cloud FL
Here's another question for you. The cab on the gas truck is pretty much toast so is the cab from a newer diesel truck the same as the gas truck? I think I'm going to take the box off the back and put a regular bed on it and a nicer cab would be a plus.
123mack
11
Jemison, AL
The cabs should be the same, except for the starter button in the floor of the gasser. When you scrap the old cab, cut out the driver floor pan and use it for a template to cut holes in the new one. It's worked for me in the past.
hndrsonj
361
Cheyenne, WY
It will depend on how right you want it. Depending on the year there's quite a few smaller differences. Do a search for gasser differences. Barman had a good thread.
