Asmoday
- 0
- 16
- Los Angeles, CA
Is it OK to re-use the timing sprocket bolt that goes thru the IP gear and timing sprocket into the camshaft?
I picked a new one up at GM for a possible timing gear swap but after checking the bolt it was determined that it's Chinese made...![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I got a new washer as well which is US made but I'm not sure if I should re-use the timing sprocket bolt as it has a fairly high torque spec...75 Ib.-ft. for a 10mm x 1.5 pitch bolt.
Opinions..?
Opinions..?
