Oddball express ii
ODDBALL007
GENEVA FLORIDA
ok ive decided to work on outer shell first cuz when i took the wire wheel to the surface rust this is what i ended up with. The military did a patch job on some rust and i think im going to do the same. So far with roof repair i have about 6 hours into the outer skin. Next ill paint it then start on inside. Also getting these reflecters off was a bit of a challenge
3dAngus
102
Perry, Ga.
Hey, where did you get that wire cup brush that goes on your angle grinder.
I like that, and it beats the heck our of using a drill.
ODDBALL007
GENEVA FLORIDA
ok did some more grinding of the flaky paint and came across some more rust holes behind the door hinge. A/C Cages gave me this liquid metal in a can. Im gonna continue to grind and fill the holes all in at once.
ODDBALL007
GENEVA FLORIDA
ok i decided to work on the back doors to address the the rust behind the hinge. Holy cow the army put in over 230 screws on these 2 doors. I took the metal plates off and discovered wood rot. Now i have to take doors of the trailer and fix them I also bought 6 super single rims so i can single out the truck. Not sure of tire size yet as i have heard different views from different people on the pro's and con's of the sizes. I also made up some mud flaps and installed.
islandguydon
787
Michigan
I guess your going to have a NEW trailer whence your done with the mod. Hows the hammer hanging Chris...? You go BOIE~~~~~~~~~
BTW the express 1 is getting a new paint job this weekend, when Stevo went to Dell's place to get the 109 from him Dell sold me 3 gallons of Desert sand paint, Since the shop is slow this time of year the guys want to repaint. I think I am going to stay with a single color and a few small brown spots.
ODDBALL007
GENEVA FLORIDA
I will have a new trailer yes
Its hanging well
Tow4
669
Orlando, FL
It'a all going to rust and rot out if Chris doesn't drain the hot tub before hitting the road!
ODDBALL007
GENEVA FLORIDA
ok i peeled one of the doors apart and i am going to have to remove the door if i want to do it right. Plus they pop rivited the seals on so im going to have to redrill them out to install new gaskets. MORE WORK UGGGHaua
islandguydon
787
Michigan
Chris thats not so bad to restore, The fiberboard I was referring to has a good insulating factor and will stop a 22 if thats any consolation.
twa@ezdn.net
19
Chesapeake, VA
Does that mean I have to use my bigger gun to shoot Chris in the butt when he starts snoring like Rayzer?
By the way, I gave you the last of them sheets of metal. I can order more if you still want them but you can also pick them up at Surplus Steel in Apopka real cheap. Just tell me before you go and I will have Heidi put it thru my account there and you get it for 75% off.
75% off! what do you have over them folks...:D
