joediveguy
- 2
- 18
- Front Royal, Northern VA
Ok, so I have seen the different posts and I need to ask, just to be sure. Can you use ATF in the 6.2 CUCV motor? I have seen two different camps, one for and one against. For being it is ok to use and against being it had additives that enhance friction which is bad for the IP.
I have a case of Toyota ATF Type T-IV left over from a Camry I once had. Is that ok to use, mixed with the diesel of course?
