My Deuce engine has a petcock mounted on the side of the oil filter/cooler housing. When the motor is running, if you crack that petcock open, you get a nice stream of oil. I presume that this is intended for obtaining a sample of the oil for testing without having to drain the sump. Also, it would be a 'clean catch' sample, ideal for testing.
My question is whether it is acceptable to use this port for a bypass filter and/or a preluber. For use to feed a bypass filter, I am not sure if this would be 'robbing' too much of the flow. For a preluber, I don't know if the pressure will go to the right place.
