Shawn MacAnanny
- 2
- 18
- Felton, DE
I got one of those all in one kits with all the filters including air filter kit. I dont know much about air compressors but i know these were designed to be hooked up with a 3/4" hose to the air box so i assumed this was where the are filter might be. I wasnt positive so i stuck my pinky finger up there to try to feel and i felt a plate and dislodged it. i assume this to be some sort of check valve for the compressor air inlet. I have also had some oil coming out of it and dripping down onto the injection pump.
I took it apart to see what it was i had moved with my finger and to see if i could find a filter or the source of the oil leak and this is what i found. The 'cork slinky' was broken into 3 pieces. I removed the 2 broken pieces and it was making a sound as if the valve wasnt sealing, after running a couple minutes it seemed to seal itself. i am not sure i put it back together correctly, i just put it back together the way it came out. The kit i had bought had one of those threaded brass/bead air filters like on most air compressors
Do they make a rebuild kit for it? Anyone know what the part number is for it or who might have one? I know check the manuals i will be doing that but i am unsure of what damage this may be causing leaving it like this. Also, just where is the filter on this compressor
