where to buy sprag
bjsmith
zachary,la
i have searched and could not fing where to buy a new sprag i have searched here and on google i need a new sprag for my duece the forward part is messed up reverse still works fine so would like to be pointed where to find new sprag or cheap air shift transfer case thanks
WillWagner
3,059
Monrovia, Ca.
Yup, save your money on repairing the sprag case. You are better off replacing the unit. 2cents
JasonS
199
Eastern SD
If I recall correctly, you can use another good used rear to replace your front. I should have one if you need. I also have a REB kit which can be used to replace your sprag section (also for sale). PM me if you are interested. However, if you have easy access to an air shift, that is a better solution.
tgarrisoniv
Middleburg FL
i gotcha. any idea how i would go about making my airlock into a manual case? maybe removing the air solenoid and making a lever? or just welding to make it all time 4wd.... i never need it in 2wd and if i did i could just remove the front d-shaft. its stricly a mud truck.
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
I think you could drill and tap some holes in the housing of the "air plunger". Then thread some bolts in to keep the plunger in place. Or pull the housing and fill it with foam? Not too sure on that. Maybe "G" will post up a better way to do it.
mikew
edmond, ok
Although it's been a couple of years, I purchased a pair of brand new sprags 2520-00-513-5811 (at a great price) from Steel Soldiers member NDT.
You can replace the sprags without removing the transfer case, just the front driveshaft output cover.
SCSG-G4
PSVB 3003
5,393
3,462
Lexington, South Carolina
The air shift really is a manual case. If there's no air pressure, it's not engaged, if there is air pressure, it engages. If you have an air shift transfer case and cap the air line coming out, then you will not be able to engage the front two wheels. That's all there is to it! The sprag is an 'automatic' in that it senses when the rear tires are going faster than the front (slipping) and it engages the front axle. Please note that where you are getting good traction on all wheels the front and rear axles will be fighting each other and you will wind up with 'less than optimal results'. 2cents
gringeltaube
Staff Member
2,654
Montevideo/Uruguay
LOL... guess he wanted a lever....??:smile:
One has to keep in mind that the -27 airshift is NOT sealed where the shaft goes through the housing wall. Also the short distance to the crossmember directly in front can be a problem to attach some kind of clevis to the -27's shift shaft end.
The only "professional" way I could think of is swapping both style front output housings WITH their respective shift shafts, while maintaining the same internal parts. So the airshift -27 fork now goes on the sprag -21 shaft (same shaft position and diameter = 7/8") which already comes with that upright arm at the end. From there up it would be easy to create the linkage and lever to operate this from the cab...
Now if this wasn't off-topic, what IS....?:p
G.
hof3414
Pittsburgh, PA
I have same problem, Sprag works in reverse not in forward. I haven't got a air shift transfer case yet but would like to in future. Whoever mentioned replacing the broken front sprag parts without removing the whole transfer case. Is this a relatively cheap part? I may do that instead of switching out entire case for now.
robert c neth
Banned
233
girard pa
the mudders usually have a good secondary market for parts.we bought 2 air shift cases for 450.00 and some good body parts because they cut these up for mud use.we also have run welded sprague clutches with no issues .remove all the clutch parts and weld the drive gear to the shaft.i wouldnt do this on a street driven truck.
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
I also forgot: last time I was at Antelope Valley Equipment, he had several dozen NOS sprag transfer cases there. He was having a hard time selling them (everyone wants air) that may be a reasonable source ($$) for a complete T/C.
JasonS
199
Eastern SD
I have a few used sprag clutches if you are interested.
mbc
Weaverville N.C
I bought mine from White Owl jeep parts last summer. Was not very expensive and was easy to change. You will need a press to remove it from the shaft.
