truck tire injuries up to 5-1/8" radially (length) x 3/4" (width) or 3-1/8" radially (length) x 1-1/2" axially (width) (wider repairs must be shorter in length) on the sidewall and 1-1/2" diameter in the crown area can now routinely be repaired, according to some tire repair material manufacturers
That means a repair completely cutting out the cording in that area, patching, filling and blending the area.SIDEWALL REPAIRS
A few years ago the International Tire and Rubber Association conducted a research study on the strength of sidewall repairs in radial truck tires. Radial truck tires with injuries 4" long and 3/4" wide were repaired, x-rayed, and subjected to increased pressure until they burst.
From the results the International Tire and Rubber Association (now known as TIA) concluded that properly repaired sidewall injuries have a strength equal to that of the surrounding tire body and provide a safe performing product for the transportation industry. Copies of this research project are now available from the Tire Industry Association/TIA, Box 37203, Louisville, KY 40233, Telephone: 800/426-8835, E-mail: info@tireindustry.org
Good idea, except the inspection station will take one look at them, see the cracks, and the DOT date, and say they are all trash.I'd likely avoid using the ones with the exposed cord even if repaier but why not load them up and pay a few bucks to a heavy truck inspection shop to give you a real answer?
Lance
You are fifty feet from a Tire Factory. Zach would probably change them in your yard if that's too far to move the truck.Dunno, I ate procrastination for breakfast?![]()
This is true ONCE they are fully aired up and seated correctly.when i had a shot replace an inner tube on mine i watched them and asked them. They said our duece wheels actually have grooved rings which makes it very difficult for the rings to blow off
