CTIS Controller problem
stutzcattle
Ohiowa, NE
Just got an A3 and then controller that was on it worked off and on. It would show the black line all the way across the screen at times and at other times it would look like arabic symbols were typed in. It even worked correctly some of the time. The unit functions correctly, it's just the display that seems to not work.
I replaced the controller with another and all I get now is the black line/boxes all the way across the screen. I wiggled the crap out of the wires and don't see any response when I do that. The unit still functions correctly I just don't have a display.
Any help would be greatly appreciated. Thanks.
lavarok
33
Fellsmere, FL
CM will repair it for you, sounds like a "minor" repair so figure about $150.
tomcata3
spring city, pa
that is the same person that sells them wcgirl222
send her an email, as far a troubleshooting you could open box ( looks like outlet cover) on unit an unplug circuit board to see if anything is burnt, I had one that was , I had it repaired and now keep as spare
Rustygears
Ramona, CA
The unit under the truck has nothing to do with the legibility of the character display. All it has are the drivers for the selenoid valves. Your problem sounds like a power or more likely a grounding issue. Check that out fully & carefully.
stutzcattle
Ohiowa, NE
I kinda wondered about a ground issue. Everything is painted so thick, that'll be my first avenue. Thanks for the tip.
stutzcattle
Ohiowa, NE
I checked the ground and it seems to be good. Again, the unit works it just doesn't display. Would it be worth replacing the entire harness?
indy4x4fab
Banned
1,711
41
indy, indiana
I would have your heads up display tested first, start small and work to big problem. The solder points may have become loose for your display and even if you did replace the hole harness it still wouldn't fix the display problem.
jaymcb
If you get contact info, please update the thread. I have a spare head unit with a dead (all black) display as well, and I would be interested in having a spare if it can be done reasonably. I wonder if they would give a SS 'group discount'? I'd have this one re-calibrated for 48-50PSI for highway driving
What I didn't know when I got my A3 was that it can take a LONG time for the CTIS to pump the tires up to 40+ PSI. It takes mine as long as 10 miles of driving AFTER a 10-15 minute warmup and PMCS.
In fairness, my A3 has 395's, which are a might bit bigger than the stock tires
748
Woodstock, GA
Why did you disconnect it? Not working properly?
The tires were all leaking down (2 would go completely flat in 6-7 days). I wanted to fix the system but after getting into it and realizing all of the potential areas for leaks I decided just to remove it and install schrader valves. It sure rides a lot smoother now.
319
Lieutenant
3,348
57
Michigan
Just wondering. My conrtol head was unplugged when I got mine and I have not played with it yet to see if it's working properly. If not, i'm not spending any cash on it, it's all coming off.
