- 12,195
- 319
- 0
- gainesville, ga.
I found the write up back in 97/98 in a MVmag, thay talked about a mwo but for some reason it was a unit by unit implementation
Thats part of the plan, I just negleted to mention it.
I noticed how the shaft kind of flopped around on the truck I removed the hubs from. For now I still plan to put bushings in them for ease of mind.
just talk to a GOOD machine shop, tell them what you want to do, thay will know what steel to use.No, not done yet. I just dont get around that fast. I have the hubs. Im a curious about what Ron said about using hardend steel rather than a softer bronze bushing. Not sure what I would need to get from the steel supply shop.
No, not done yet. I just don't get around that fast. I have the hubs. I'm a curious about what Ron said about using hardened steel rather than a softer bronze bushing. Not sure what I would need to get from the steel supply shop.
Not sure. If I can, I'll take some photos of it apart.Whats the spindle set up on a 900? Is it like the deuce with the two supporting bushings,or the 800 with the single bushing?
Can you share the source you used for the bronze bushing material you used,. or perhaps suggest one for the home machinist?Here are a couple of pics of my modified front axle flanges. I turned out the spline area to an O.D. of 1.95". I shrunk in bronze bushing material and turned it out to an I.D. of 1.64". The major O.D. of the axle spline is 1.625". That gives me about 0.015 clearance for free running in grease.
I saw the work that you did and I think it looks great. I also think that the bronze will work just fine in this application.I used bronze bushings because I wanted them to be softer material than the axle splines. The bushings are easy and cheap to replace. I used a bronze 2" boat propeller shaft for my bronze material. It was a short piece left over in a scrap bin. As you can see from the pictures, I also drilled, tapped and put zeros in the end of the flange cap for greasing.
Not sure where this info. came from but it is incorrect, the A3 is the same spindle as the A2, modified with an air port , they both have a bushings in the spindle.I have run desplined hubs for many years. They work fine. However those of you with M35A3s do not want to run them unless you put some sort of support in the end of the hub to hold the shaft. There is a bushing in the non A3 axles that was left out when they modified the older axles to handle the CTIS. So if you have no support on the end of the hub the shaft will drag on the inside of the wheel shaft opening. Ask me how I know that and I will tell you about the heat generated by letting the axle drag on the shaft tube.
I could wright a complete page on this one. I will start with one - "spinning side gear" - where is the gear oil coming from to oil all these moving parts. If the drive shaft is not turnning it and axle is not turnning it, there is NO oil moving moving because the main large drive gear in the dead sitting in the oil? These moving parts will burn up with out oil. I have a rockwell front on the stands with oil in it. If the oil level is high, in the center of the site plug, this will lude the inturnal gears and work. If the oil level is low, a knuckle down, these gears are toast.There is no reason to run two except for the emotional appeal of elegant symmetry.
If you run one, the axle on one side runs forward at road speed. The diff carrier is not turning since the transfer case is not engaged. The other (disconnected) axle stub turns in the opposite direction at road speed. Yes, the spider gears are precessing around to make this happen.
Spinning spider gears this way under no load and in a bath of gear oil produces no wear. They will do this from now until the end of time, no problem.
For the same reason, you only require one lockout hub. Most folks run two, because it seems that you should have two. Detroit has built millions of trucks that split only one axle to disconnect the front drive for a good 25 years or more. It obviously does not cause a problem.
