quick disconnect battery cable connectors
sully429
Pa.
has anybody had any success with quick disconnect battery cable connectors. and if so what brand and where did you get it. thanks
doghead
4 Star General /Moderator
1,175
Use your shift key to capitalize the first letter in the first word in every sentence. This has been a grammar standard that we all learned in 3rd grade.(It's also a site rule)
There are issues particular to CUCVs, and using a single cutout switch is not a good idea.
Do some searching, we've covered this before.
Matt65
Alabama
Welcome to the Forum!
I think what you are asking about I have an image of below. I have never used these. My truck came with a heavy Keyed disconnect in the cab. Other than added security I have never had the need for further disconnectability since doing the DogHead Relay. Like DH mentioned the CUCV's electrical system is different than civilian trucks. You may indeed need two of them for each Positive battery terminal to achieve full disconnect.
Why exactly do you want to add them? Knowing why you want them may help us provide a better solution vs. these terminal ends.
sully429
Pa.
use your shift key to capitalize the first letter in the first word in every sentence. This has been a grammar standard that we all learned in 3rd grade.(it's also a site rule)
there are issues particular to cucvs, and using a single cutout switch is not a good idea.
sorry doghead
doghead
1,175
Not so sorry you would follow the rules(and my advice).
Sorry you can't post for a while.
