Blue2actual
- 23
- 18
Can anyone verify that If your serial # starts with 1GCH that you have an M1028, as opposed to an M1008? Because if that's the case, then I have been wrong about my truck all along.
unless I am blind, I see nothing about VIN info, minus the J code 6.2Read the FAQ section.
http://www.steelsoldiers.com/cucv/20600-faq-thread-cucvs.html#post217489Can anyone verify that If your serial # starts with 1GCH that you have an M1028, as opposed to an M1008? Because if that's the case, then I have been wrong about my truck all along.
matt, CARNAC's info on my truck said it was an M1008 so that is what peaked my curiosity....http://www.steelsoldiers.com/cucv/20600-faq-thread-cucvs.html#post217489
You may also be interested in this thread.
Does your Vin on the dash match the Vin # on the data plate(located inside drivers door jam)? If so, what is the NSN listed on the data plate? And was any MWO done?Can anyone verify that If your serial # starts with 1GCH that you have an M1028, as opposed to an M1008? Because if that's the case, then I have been wrong about my truck all along.
