No Air in Service Brake connection for trailer
JohnDeere
Oklahoma
I noticed that when I removed the left gladhand cover, and opened the valve next to it, no air came out at all.
However the valve on the right side, on the line marked "emergency", releases air just fine when I crack it by hand.
Is there a secret valve somewhere I don't know about?
Srjeeper
40
NE, Pa.
Do it again and listen when you step on the brake pedal. You should only get air out the service side when the brake is applied. This is an air over hydraulic system not an all air system...[thumbzup]
JohnDeere
Oklahoma
Thanks for the replies...Just got this truck 3 weeks ago.
I have aired up the tires using the right side, so I just fiqured air should come out the left side too.
quickfarms
25
Orange Junction, CA
It is the same
The emergency line removes the spring brakes, if so equipped, and fills the air tanks.
The service line applies the brakes by sending an air signal to the relay valve.
Srjeeper
40
NE, Pa.
JD, always better to ask first then find out the hard way later. Here's a good site to get copies of the TM's FREE and other quality parts or info for your truck....
http://www.jatonkam35s.com/index.htm
When time & money allow, and ya feel the need to start pickin up Do-Dad's (that's RedNeck for Bling) always look to our sponsors first...then if you can't find it...aua,
there's others out there...[thumbzup]
Some simply better than others, so again, just ask..:doh:
