Jesse6325
- 1
- 0
- Orange Grove, TX
Ok, I thought I'd post some photos of what I found when I was taking apart the rear end to replace the torque rod bushings.
The reason I pulled the spring and spring hangar off is it was loose, Did not want to just re install it without taking a good look.
So far what I have found are two badly rusted "U" bolts, The spring hangar full of crud around where the "U" bolts pass through and a really crusty crusty spring hangar,,,
I'n going to clean up the hangar as good as I can then use something like Ospho in steroids on it (Something we use at work, A good deal better than plain Ospho) Then, After I get everything back togeter I am either going to fill the cavities around the "U" bolts with heavy grease or roofing tar. Hopefully to keep dirt/mud/sand from collecting and eating everything away
.![Ubolts02.jpg Ubolts02.jpg](https://www.steelsoldiers.com/data/attachments/231/231196-ea1e5e5f5ce7ce27949ce8be2517bc0c.jpg)
![Spring hangar 01.jpg Spring hangar 01.jpg](https://www.steelsoldiers.com/data/attachments/231/231197-4a1f634a2d62486c285c0568cd1d1a29.jpg)
![Spring hangar02.jpg Spring hangar02.jpg](https://www.steelsoldiers.com/data/attachments/231/231198-b2186d9e073e189c1a37b57b4f7fe74b.jpg)
![Spring hangar03.jpg Spring hangar03.jpg](https://www.steelsoldiers.com/data/attachments/231/231199-392629afdcd6c32f03a77ab30ca27941.jpg)
![Spring hangar04.jpg Spring hangar04.jpg](https://www.steelsoldiers.com/data/attachments/231/231201-d93a8a366f3a79487714de3be794a935.jpg)
![Spring hangar05.jpg Spring hangar05.jpg](https://www.steelsoldiers.com/data/attachments/231/231203-48563e3c524628d4b18483d653890fec.jpg)
![U bolts01.jpg U bolts01.jpg](https://www.steelsoldiers.com/data/attachments/231/231195-1c8045daee9ddcc18bbb5e0ff77c33b8.jpg)
