Accessories
M1008driver
Great Falls, Montana
I've been wanting to install some radios and other electrical devices to my M1008. I was thinking about the wiring and how my fuse block is getting old, so I came up with a new idea.
This auxiliary fuse panel is compact (3.0” x 2.4” x 1.25”) and easy to install. My plan is to use the 12 volt junction on the firewall under the hood. I chose this model for the ease of installation and adding electronics. I plan to use a fusible link too as added protection.
I would shop around for better shipping cost if you buy.
Automotive Fuse Panels From Centech
Mainsail
1,763
Puget Sound, WA
If you're going to put it under the hood, maybe it would be more appropriate to use a marine fuse panel that was made for damp conditions.
A quick search on amazon finds this one that's not only marine grade, but less expensive.
stationjj
Middle Tennessee
I have 2nd fuse panel for radios and such on my M1009. A friend helped me install some relays that will energize the panel with engine turned on. It works well no problems.
I second Mainsail advice on the marine grade panel. It's a great panel, and the price is right. I believe it's made by Blue Sea Systems.
John
KK4LNG
