I think the one I pictured is an M123C.
What is the difference between the M123C and M123A2C?
Sorry m123a1c I mean, they have the refitted cummins diesel engine in them, not the gasser engine.
engine- m123 LeRoi T-H844 V8 Gas 297hp@2600rpm
engine- m123a1c Cummins P1525 V8-300 785 cu in, diesel 300hp@3000rpm
Transmission- Constant mesh Mack TRD XT72 5 fwd, 1 rev
Transfer case- Mack constant mesh 2 speed (integrated w/transmission)
Front Axle Mack- triple reduction
Rear Axles- Mack double reduction
Differentials- Mack 10:1
Winch- Garwood 45,000 lbs
Fuel capacity- 2 tanks, 83 gal each
Cruising range- 300-350 miles
Maximum speed- 43 mph
Weight- M123- 32,250 lbs
Weight- M123A1C 29,100 lbs
Length- 289 inches (7.34 m)
Width- 114 inches
Height M123- 113 inches
Height M123A1C- 108 inches
Towed load rating- 120,000 lbs highway / 80,000 lbs off highway
