joshs1ofakindxj
- 43
- SW PA
I did some searching and got conflicting answers.
I want to install fuel gauge(s) to keep an eye on the condition of my fuel system and particularly the fuel filters because I run waste oil.
I thought I read that the pressure delivered to the injection pump was 6-8 psi, so I got a small Mr Gasket fuel gauge and plumbed it to the port where the breather is located on top of the secondary fuel filters.
The gauge was pegged, so I put on a 0-120 psi gauge and it gave me the readings I wanted I believe. I was surprised it varies with throttle. I thought I would be seeing a steady pressure from the tank pump. I'm seeing 30 psi at idle, 60 psi at normal cruise, and 80 psi when ready to shift up.
Would I find the 6-8 psi anywhere is the system?
Am I seeing the correct fuel pressure readings at the secondary filters?
Thanks!
Thanks!
