Questions on air tanks
TJP
PHX/AZ
found pin holes in my air tanks yesterday:(. Would like to know if anyone has found a aftermarket tank that fits. I have found used original for sale but worried about same situation.
Any info would be appreciated.
Thanks
319
Lieutenant
3,347
58
Michigan
Floridianson
2,527
Interlachen Fl.
Used is one way to go. If you buy new aftermarket watch it there are some tanks that are the right size but have two different cells. You have to take a extra long drill bit and drill a hole in the divider inside the tank.
TJP
PHX/AZ
Thanks
If I go new I will watch for that.
wdbtchr
St. Louis, MO
That may be the kind I needed for my DTC 8606 Froklift. It had a two compartment tank wet side/dry side setup. I couldn't find one when I needed it so I took a new larger one for a semi trailer and mounted it on the hood because there just wasn't room underneath. 2cents
Flyingvan911
158
Kansas City, MO
And be sure you can drain the water out of both sides of the tank.
