Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
found pin holes in my air tanks yesterday. Would like to know if anyone has found a aftermarket tank that fits. I have found used original for sale but worried about same situation.
Used is one way to go. If you buy new aftermarket watch it there are some tanks that are the right size but have two different cells. You have to take a extra long drill bit and drill a hole in the divider inside the tank.
That may be the kind I needed for my DTC 8606 Froklift. It had a two compartment tank wet side/dry side setup. I couldn't find one when I needed it so I took a new larger one for a semi trailer and mounted it on the hood because there just wasn't room underneath.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
